1 - 2 of 2 Posts
Trying to remove the audio controls off the steering wheel so I can pull the air bag. Want to check what the internal hardware of the wheel looks like as I'd like to replace it and want to be sure what I buy will work. So on the audio controls... I cannot find a Sienna or Camry steering wheel removal video where there are audio controls. I pulled off a small access panel and a T20 removed the single screw. I'm guessing I need to slide forward or back while pulling, or something like that, but don't want to force the issue and break a tab. How the heck does the audio control assembly come off the steering wheel?
Discussion Starter #2
Stereo Component Controller
Steering Switch
Those are the two names in the service manual the steering wheel audio controls are called. I managed to remove the assembly. After removing the small cover at the corner, remove the single screw. T20, I believe. With the screw removed pull the entire assembly toward the front of the steering wheel about 1/8" to 3/16". It can then be removed.
46469
46470
46471
46472
1 - 2 of 2 Posts
