A few months ago, I got the thing to run after three years of sitting by replacing the front manifold/cat converter, and doing a few other things. Moved it out of the shop (didn't really want to, but had no choice), but it doesn't stay alive for long. Finally got a code reader, and now can do some diagnostics on it. I can't read live data because my reader doesn't do that, and the engine won't stay alive for long at all anyway.
Seeing that the misfires are specific to bank 1's cylinders, it would be easy to assume that the bank 1 cat is also clogged. Makes sense, and that'll be the first thing I check. If its clogged, hopefully replacing that will clear up the misfires, and I can tackle the other codes next.
P0018 bothers me. The timing belt was replaced about a year before it broke down, so I would be shocked if it is worn already. Could it have slipped timing somehow? I personally, never touched the timing components.
P0051 is odd, the O2 sensor is new...
Both P0018 and P0051 are problems in bank 2, so I am guessing they're not directly related to Bank 1's issues.
Been concerned about what caused the cat(s) to clog. I may have found a cause. There is a significant amount of oil that builds up in the throttle body whenever I start it a few times. Pulled the PCV valve (first suspect) and did the "shake and hear it rattle test". It rattled. This doesn't necessarily mean it is good, but its a good start. What else in the PCV system could do this? I've read cylinder blowby could cause this as well, so I could do a compression test I guess, wouldn't hurt to try that anyway. Worst case scenario, we have to rebuild it, which was the initial plan anyway!
I was advised to check fuel pressure in my first post. Not a bad idea, and I'm still willing to do it. At this point though, I'm not sure this is my big issue. Perhaps do compression test first? What do you guys think?
Looking for anyone's two cents and experience here, the thing has been used hard and possibly not maintained in the best way? Not sure, I was a child for most of its service, so I don't remember at what intervals it got oil changes and such. It used to be a daily driver, but it is comforting that these engines are pretty resilient.
