Any idea why Toyota when with led for all exterior bulbs except license plate, reverse, and turn signals??? Who leave those 3 out?
9 x 194 LED for 2nd row, cargo area, driver/passenger door, and license platesThis thread is awesome, lots of good information. Could someone please post number of lights we need for each category below? They seem to come in packs and I don't to order less or more than needed.
29mm Festoon LED for window visor
31mm Festoon LED for 3rd row
Here is what I was thinking to get -
Backup Reverse Light Bulbs -
AUXITO 912 921 LED Bulb for Backup Reverse Light Bulbs, 2600 Lumens 4014 42-SMD, 6000K White, Non-Polarity 906 W16W T15 921 LED Bulb Direct Back Up Replacement Lamp, Pack of 2 https://a.co/d/hShZFiT
194 LED for 2nd row, cargo area, driver/passenger door, and license plates -
AUXITO 194 LED Light Bulb 6000K White 168 2825 W5W T10 Wedge 24-SMD 3014 Chipsets LED Replacement Bulbs Error Free for Car Dome Map Door Courtesy License Plate Dash Instrument Lights, Pack of 10 https://a.co/d/72EOtWj
EverBright White 29MM Festoon Led for Car Visor Mirror Lights, 6641 6612F 7065 Led Festoon Bulb 12V Dome Light, 4014-9SMD, Pack of 10 https://a.co/d/82WBCKK
31mm Festoon LED for 3rd row -
AUXITO CANBUS Error Free 4-SMD 3030 Chipset 31mm (1.25 inch) DE3175 DE3021 Festoon Xenon White LED Bulbs Replacement for Map Dome License Plate Lights Lamps (Pack of 4) https://a.co/d/agF1aZH
my bad, I forget the 2 x license plate bulbs.This thread is awesome, lots of good information. Could someone please post number of lights we need for each category below? They seem to come in packs and I don't want to order less or more than needed.
Edit - Updating this post with number of lights needed for each category
7 x 194 LED for 2nd row, cargo area, driver/passenger door, and license plates
4 x 29mm Festoon LED for window visor
1 x 31mm Festoon LED for 3rd row
2 x 7440 7443 LED Bulbs for rear signal blinkers
2 x 912 921 LED Bulb for Backup Reverse Light
Rear signal blinkers -
AUXITO 7440 7443 LED Bulbs Amber Yellow 400% Brighter T20 7440A 7441 7444 7444NA W21W LED Bulb with Projector for Front Rear Signal Blinker DRL Side Marker Tail Lights https://a.co/d/0RcxHHF
29mm Festoon LED for window visor -
Yup, and they just happens to be the hardest ones to change. I still have my LED bulbs here somewhere as I could not change them. The owner's manual is not exactly of great help either. I think there is one video on youtube about it but the guy puts the camera down on the ground when he is changing it so we cannot see exactly how to change.my bad, I forget the 2 x license plate bulbs.
I have to agree on the map lights. I posted somewhere earlier about changing out the lights on the two visors. In practice, using the visor lights when I would otherwise use a map light has proven to be a fantastic work around for the soldered map lights. They give off plenty of bright light, and for those times when someone doesn't want something so bright, the map lights work for them.I agree: This thread is totally awesome, most helpful and added a huge value in my owning/driving experience.
The difference, after changing all the internal lights except the map ones, is poles apart. The driving/owning experience with the brighter (happier) LED lights is truly augmenting and enhancing the joy. Which only leaves me to imagine how significant of a jump in a happier experience it would be to change the map lights too. Such a shame, they are soldered onto the circuit board and as such not too easy to replace.
Also, once again a huge thank you to everyone who chimed in with their experience, and shared amazon links for the bulbs alongwith helpful information. To the OP, I owe you a coffee for sure (*thumbs up)
Successfully changed all the lights, including rear flashers, backup and license plate lights. Too bad we can't change the map lights. I saw a video on YouTube for highlander with same issue and that individual appears to have figured a way and will be uploading a video soon, hopefully it's as simple as other lights. Will update if I find anything. Thanks everyone on this thread for all the details which made my work easy.This thread is awesome, lots of good information. Could someone please post number of lights we need for each category below? They seem to come in packs and I don't want to order less or more than needed.
I remember reading somewhere that the LE does have the wiring harness hidden inside, maybe it’s taped far enough inside you couldn’t see/feel it? Maybe someone with an LE who had the door panel off could give a definitive answer.I have a 2021 Toyota sienna le and I discovered that it doesn't have Puddle Lights at all. In the same place is a red trim cover with no lights and wiring harness inside. I want to add a Puddle Lights does anyone know how I can do this? Does anyone know the actual part number for the wiring harness from Puddle Lights
I also think it is impossible for toyota to design a special harness alone for LEI remember reading somewhere that the LE does have the wiring harness hidden inside, maybe it’s taped far enough inside you couldn’t see/feel it? Maybe someone with an LE who had the door panel off could give a definitive answer.
There are diferent part numbers for the door wiring harness. I took the door panel off of my 21 LE to confirm and I could not find any evidence of the wiring needed for putting in courtesy lamps. The photo below on the left was posted by @cowdog360. I highlighted the light wiring. The photo on the right is from my LE.I have a 2021 Toyota sienna le and I discovered that it doesn't have Puddle Lights at all. In the same place is a red trim cover with no lights and wiring harness inside. I want to add a Puddle Lights does anyone know how I can do this? Does anyone know the actual part number for the wiring harness from Puddle Lights
Thanks for confirming. It wouldn’t be too hard to just pull the wire in. There is pre-wiring for the lighted door sills accessory you can tap into.There are diferent part numbers for the door wiring harness. I took the door panel off of my 21 LE to confirm and I could not find any evidence of the wiring needed for putting in courtesy lamps. The photo below on the left was posted by @cowdog360. I highlighted the light wiring. The photo on the right is from my LE.
That's a great idea. There are some aftermarket kits that include the pigtails for wiring them in on Toyota's without preexisting courtesy lamps. Just picked up a pair. Here is the link for anyone interested. A quick search led me to some folks with gen 3s that installed them successfully.Thanks for confirming. It wouldn’t be too hard to just pull the wire in. There is pre-wiring for the lighted door sills accessory you can tap into.
I saw this on ebay For TOYOTA SIENNA 2021-on LED Puddle courtesy door lights welcome super bright | eBayThat's a great idea. There are some aftermarket kits that include the pigtails for wiring them in on Toyota's without preexisting courtesy lamps. Just picked up a pair. Here is the link for anyone interested. A quick search led me to some folks with gen 3s that installed them successfully.
Chinese market option. Not for North America.The figure in post #11 implies a panoramic roof is coming; or is already available in another market?
