As I posted a while back about a road trip in June coming back from a cross country trip I had one of the 2 tee's fall apart while on I-40 it was cool and rainy so I saw the mist right away from under the hood caught it in time had a tow to Moriarity NM. about 39 miles from where I pulled off the interstate. A shop repaired it for 300 bucks They used a brass pex fitting 3/4" and used screw type hose clamps for the job. I was good with that well still am. So today I figured I better do the other one that is left so I bought a brass tee 3/4" pex and 3 new screw clamps I think the cost was 12 bucks... LOL AS I removed one of the factory pinch / squeeze clamps I saw that one end was starting to crumble apart. I am glad I finally got around to it as I am getting ready to go on a fall trip. I am glad I did not wait as when I started to remove the pinch/ squeeze clamp OEM I could see the tee crumbling it was only a matter of time till it would leak. So the Moral of this story is DO NOT WAIT.. Change them both My 2008 XLE is alive !
Automotive fuel system Automotive tire Motor vehicle Car Automotive exterior
Motor vehicle Automotive air manifold Gas Wood Auto part
Automotive tire Motor vehicle Hood Automotive wheel system Auto part
Fluid Bicycle part Cylinder Gas Nickel
2006 LE
That is indeed good advice. I was made aware of this issue couple years ago by an ex siennachat member who had an 08 Sienna with almost 400k miles. Earlier this year I renewed the coolant and replaced both Ts with the oem plastic ones as a preemptive measure. While removing one, it broke like yours did. 06 Sienna now with 205k miles.
OEM part number, T plastic fittings ……..87248-60460. These are conservatively good for 150k miles YMMV.
Reactions: Craigrrr
Thank you so much for this. Is there a difference in size between a 3/4” PEX and a regular barbed tee? I am totally doing this asap.
