Anyone with any input concerning swinging front doors wider open? Any help is appreciated.
Thank you for the reply. I have been able to find people doing it to the Honda Ridgeline truck back doors on YouTube. I just wonder if it is possible to do it in the sienna on the front doors because I am about to have the front passenger seat converted by a mobility company.Sorry. I don’t know the answer, and this is the first I’ve even seen this type of question after a few years of being here.
You might potentially have better luck asking the experts / technicians at a dedicated conversion place like BraunAbility who modify these vans everyday for mobility.
Toyota Sienna Hybrid Wheelchair Van | BraunAbility
The all-new BraunAbility Toyota Sienna Hybrid is spacious, sophisticated, and styled to seamlessly match the Toyota Sienna in both dependability and design.www.braunability.com
Actually that is what I am trying to get to. Has anyone found a longer door check and done it before to this van? Or is it even doable at all for front doors due to the leading edge curvature issue. With the Honda Ridgeline truck, the rear door hinge leading edge line is pretty much straight, without the curvature.I don't own a 4th Gen Sienna so I can't verify... but on the 3rd Gen the door check is attached to the B-Pillar with a very simple single bolt bracket, and the check swivels on bracket with what looks like a push-in pin. Net is that anyone could test this by unpinning the check and CAREFULLY!! moving the door further out to see how far it can extend before the leading edge of the skin contacts the frame.
Assuming there is a little more latitude available to meet your needs, an extension could be fitted, or you'd need to begin the search for a longer replacement plastic check.
Thank you for the reply and insight.Are you putting in a new unit or transferring the one from your 2012? Often the mobility company gets parts with the install for the vehicle and seating position that is requested. If transferring an old one they should contact the manufacturer for specific bracketry for the vehicle it is now going to be installed in. That should include instructions for installation and often these address door mods. Some are as simple as adding spacers and some require welding extensions. I have done both. Also keep in mind that there is often a lot of airspace behind the plastic of the door panel and modifying that can give a lot of room for your knees. I have always built for the client that needs it and most of the time can make the mods look clean if not close to OEM. Worst case scenario go to a lowrider shop and make the door Gull wing. It will help keep the rain off while transferring.
Sorry to say that I am all the way across the country in San Diego, Ca. I would try to contact Adapt directly. It may be that the dealers you are talking to don't service their equipment. I have been out of the business and am retired but I do know that many of the dealers are wary of installing units that are not ok'ed by the manufacturers because they belong to a group called NMEDA. It is self governing and NOT LAW in many of the cases that they refuse to do. There are many concerns about airbags and safety that will be very important to note in any modifications. I am unsure if your seat is Bruno or not. There should be a manufacturers tag somewhere on it to better identify what you have. There were other companies besides Bruno. Yours may be a Freedom from Adapt. I have modified vehicles all my life. I installed EMC systems so you could drive with a joystick. I built a DARPA Grand Challenge autonomous vehicle. I've built RV's out of vans and cross country Greyhound busses. You just need to not be afraid to do some research and think out of the box. On the other hand you are cutting up and modifying your brand new vehicle. I've done this for years so I still get people calling for advice once they find me. I have a Sprinter rv conversion showing up next weekend from Vegas that needs a transfer seat and hand controls and I have yet to meet the owner who lives in Arizona. The difficulty is finding someone that owns a tape measure, is mechanical, is creative, thinks things out, and you trust.Thank you for the reply and insight.
Let’s get down to business. I was trying to have my Toyota Factory installed 2012 Sienna Auto Access seat transfer to my new 2023 sienna. All of the mobility companies I talked to don’t want to transfer “old” seats. The seat that came with Toyota, I believe was made by Bruno (the original inventor of the seat. But Toyota claimed they manufactured it). Mobility works claim that Bruno was sold out to Braun Mobility, which now sells a watered down version of that seat call Turny Evo. All mobility companies claim that they can’t transfer the old seat due to no transfer kit available or some other reasons.
Now I am forced to buy a new seat and can’t install the Adapt Solutions Link in the mid-row right position since my 2023 sienna comes with ottomans. What’s left is to put it in the front passenger position with very tight clearance. In fact made a 50% deposit down payment a few hours ago for it.
I was told I will loose the seat ventilation function, the seat shroud needs to be trimmed. The “B” pillar needs to be trimmed. I can only imagine there will be a hole somewhere in the B pillar besides the tight clearance.
May I ask, are you a mobility installer, and where are you located? You mentioned a lot of the stuff I wanted for my install that is wishful thinking from
All the mobility companies I spoke with.
I always joked about only if I can have gull wing door for my 2012 all these years simply because it will serve really well during rain transfer. You said you have made mods to door panels too. Can you give me any insight into this? Where are you located? I am in Florida.
I am guessing it is Bruno because the base shroud and buttons looks exactly like the Premium Class Seats that Bruno offered. It did came with my 2012 Sienna Toyota factory installed. The van was a special order. No labels anywhere to be found. This is dating back 2011.Sorry to say that I am all the way across the country in San Diego, Ca. I would try to contact Adapt directly. It may be that the dealers you are talking to don't service their equipment. I have been out of the business and am retired but I do know that many of the dealers are wary of installing units that are not ok'ed by the manufacturers because they belong to a group called NMEDA. It is self governing and NOT LAW in many of the cases that they refuse to do. There are many concerns about airbags and safety that will be very important to note in any modifications. I am unsure if your seat is Bruno or not. There should be a manufacturers tag somewhere on it to better identify what you have. There were other companies besides Bruno. Yours may be a Freedom from Adapt. I have modified vehicles all my life. I installed EMC systems so you could drive with a joystick. I built a DARPA Grand Challenge autonomous vehicle. I've built RV's out of vans and cross country Greyhound busses. You just need to not be afraid to do some research and think out of the box. On the other hand you are cutting up and modifying your brand new vehicle. I've done this for years so I still get people calling for advice once they find me. I have a Sprinter rv conversion showing up next weekend from Vegas that needs a transfer seat and hand controls and I have yet to meet the owner who lives in Arizona. The difficulty is finding someone that owns a tape measure, is mechanical, is creative, thinks things out, and you trust.
Best of luck. It may well be it can't be done. But it isn't rocket science.
Yes, from mid-row right to mid-row right. That was exactly what I wanted to do since the seat in the mid-row right is actually newer and in better condition than the van. It's perfectly usable and why waste it. Besides, the seat aesthetically looks superior and mechanically works superior with build in forward/backward and leaning functions while entering/exiting the van. And not to mention remote control fobs which none of the new seats come with. They come with a very ugly looking old fashioned dongle on a phone curly able that has no place to sit properly when not in use. It cost even $7.5k back then. They all shook their heads. I was frustrated for almost 2 months for this shortly after placing a deposit for my new van. Finding a van at MRSP was difficult enough. Waiting for it was even more of an issue. Finding out that the New Adapt Solutions Link seat can not (they will not) install it in the Mid-row right position because of the Ottoman. Toyota would not modify the order with no ottoman. Mobilities refuse to install even after I stating I will modify the seat with original parts to acommadate the installation. I kind of hated myself for it during the whole process since I opted for the nicer 25AE version just wanting to have my mom ride in style just like the rest of us in the van. Low and behold, it was exactly that action that prevented the install.So you originally wanted to move the seat to the second row at the sliding door? That should be easily accomplished. Pity you aren't closer or planning a cross country vacation. Typically the most difficult part is finding me. It just means that you don't get the NMEDA sticker on your driver side B pillar. Yes, as a member of NMEDA they do record and report the modifications. As an owner you can pretty much do anything you want to your vehicle. Also note that an OEM seat from a wrecking yard should bolt right in to your old van for resale. You may need some of the OEM connectors and wiring pigtails for the airbags to solder in.
Yes. I am committed (stuck) with front passengers position since I already paid 50% for it yesterday. Reasons for the decision:It sounds like you are committed to the front seat position now.
As to transferring mid row to mid row you should not need to reprogram. there should be plenty of room and a tale of the tape (measure) would tell you where to place it. The only wiring should be power and ground.
Addressing NMEDA. My boss at the time was one of the dealers instrumental in creating the organization, The idea was if they created a self governed organization it might (did) keep the government from doing it for them. Over the years there have been some tightening and restrictive measures taken that keep some of the lifts from being available in the U.S. primarily to protect us from ourselves (ignition, shift, and e brake interlocks) although some were still built here and available outside of our country (Braun swing-a-way lift). This and attorneys have made it so manufacturers are specific how items can be installed. A good idea overall because there are some hacks out there.That, and some of us do need to be protected by ourselves. I wonder how many people may have driven the neighborhood with a their kid outside on a turney seat to deliver newspapers or flyers. I have replaced some wheelchair lifts because people forgot to close the van and drove away with them out.
Thanks for the info and extensive knowledge shared from the trade. Now I see why these dealers are unwilling to do anything.If you try to sell the turny seat separately it may be best to keep it in til sold so someone can see it operate and take measurements. If you want to sell it with or without the van a good source may be to post it on blvd.com where it may get good nationwide exposure.
Thanks Good suggestionsIf you try to sell the turny seat separately it may be best to keep it in til sold so someone can see it operate and take measurements. If you want to sell it with or without the van a good source may be to post it on blvd.com where it may get good nationwide exposure.
Congratulations and good to hear you are finally closing on your mobility conversion van. Getting below asking prices is very good. Getting more for your RAV 4 trade-in than what you paid for is even better. Was the trade made with the mobility company? One of the mobility dealers did not want to give me any discount when they want to sell me a conversion when asked. I like VMI better than BraunAbilify even thought they said Braun is better. Being a Platinum AWD must be really costly. A regular non conversion Sienna Platinum cost over $51k MSRP.Has the Link arrived yet? Has it been installed yet?
I close tomorrow on the 2021 Sienna Platinum AWD VMI conversion. I was able to get a decent discount below their asking price, and am getting more for my 2022 RAV4 trade-in than what I paid for it. Still more than I really want to pay
