1 - 20 of 309 Posts
2021 Sienna Platinum
Hello SiennaChat Folks !!!
My disclosure :
I am a participant in affiliate programs including the Amazon Services LLC Associates Program. Affiliate programs are designed to provide a means for me to earn fees by linking to Amazon.com and affiliated sites. As an Amazon Associate I earn from qualifying purchases. All Amazon and affiliated linked items are ones that I truly love, fit my style, and use on my own vehicle. Feel free to learn through my experiences and reviews first hand.
Previously, I built / customized a 2010 Toyota Prius III for both the SEMA (Specialty Equipment Market Association) and the CES Show (Consumer Electronics Show) in Las Vegas, Nevada.
Here is a photo of my Prius (in Blizzard Pearl White) from a ToyotaFest photo shoot in 2021 :
50776
I took delivery of the 4th Generation Sienna on 06/17/21 here in Southern California.
Here are photos from Day 1 from Longo Toyota, Toyota dealership in Southern California :
50778
50777
First addition : SEMA brushed aluminum license frame :
50779
50780
50781
The Bullet Train / "Shinkansen" in Japan is an inspiration for my build.
I will be sharing my experiences and modifications here on Sienna Chat as well as on Instagram : @Toyota_Shinkansen.
Feel free to follow my journey !!!
- Rodney
Discussion Starter · #2 · (Edited)
First Modification : LED License Plate Lighting
Hello Folks !!!
Installed this First Modification on 06/20/21.
Replaced the OEM Single Bulb with a 3W 18-SMD LED Panel complete with Housing.
This set is available here : OEM-Replace 18-SMD 3W LED License Plate Light Assy For Toyota Camry Prius C, etc | eBay
50786
Check your Toyota Owner's Manual for details on how to remove the license plate lens. Because I replaced the whole housing,
I removed the rear panel inside to access and remove the complete housing.
Sorry, I do not provide DIY Instructions / Walkthroughs.
50785
The mini-screw driver was taped to provide extra protection not to mar the finish :
50787
The OEM single bulb (Right) was replaced by an 3W 18-SMD LED Pane (Left) :
50784
Comparison of the OEM (L) vs. the LED (R) when lit.
50788
And ... complete !!!
50789
Overall, I'm very happy with this LED Lighting upgrade.
It provides great safety visibility without blinding rear drivers as the panel is pointed downward. And, when backing up at night, it provides additional bright lighting.
Stay tuned for more modifications coming soon !!!
- Rodney
Discussion Starter · #5 · (Edited)
ooh sexy led panel vs bulb led style, may have to go for that
I just used these for the license plate bulb replace. Worked great. Another benefit? Beauty is you can use the same ones to replace the 2nd row bulbs, rear cargo area, and lower driver and passenger side door lights and it’s only $10 for ten.
Discussion Starter · #9 ·
very cool! looking forward to see the Shinkansen build(it just occurred to me that you could actually pull that off. I got the white XSE and am looking for some easy ways to personalize it.
Congratulations on your XSE @Fishingvan !!!
I'm really excited to share my experiences throughout this journey !!!
- Rodney
Discussion Starter · #10 ·
Hello @Vanfam12345 !!!
Thanks for the info, I will be looking at interior lighting soon.
- Rodney
I changed mine to something else suggested in another thread as well. But the panel and complete replacement is what sold me here :D
Discussion Starter · #13 · (Edited)
Hello Sienna Chat Folks !!!
The latest Modification is the OEM Toyota Mudguards !!!
This set for LE, XLE, LIMITED and, PLATINUM models are available here : 2021 SIENNA LE XLE LIMITED PLATINUM MUD GUARDS SET PK389-08M00-TP GENUINE TOYOTA | eBay
The set for XSE model is available here : 2021 SIENNA XSE MUD GUARDS SET PK389-08M10-TP GENUINE TOYOTA | eBay
50814
To save money on installation costs at the dealership, I do my best to install as much as I can by myself.
And, you can also obtain installation instructions from your local Toyota dealership / Parts Department.
50815
Tools needed : Phillips screwdriver and a 10mm socket / wrench (not pictured).
50816
All 4 Mudguards are labeled and all necessary hardware (screws/brackets) are included in the kit.
50821
There are pre-dimpled areas where the new screws will be installed :
50817
Installation :
50818
50819
And complete !!!
50822
Overall I am pleased with OEM quality finish and fitment. With this being a new vehicle I am rest-assured that they will provide great protection for the fenders' / doors' painted surfaces.
Happy Modding !!!
- Rodney
Any tips on removing the covers for the side door lights? Do the just pop right out?
Thanks!
Pretty much pop right out. I used a thin flat head screw driver covered with a piece of blue painters tape. Very gently inserted at the corner and very gently nudged it. Quite easy, really. Took maybe 20 seconds.
Just note: I'm not referring to the puddle lights on the side mirrors... I'm referring to the light on the lower interior of the driver and passenger side door panels.
Discussion Starter · #17 · (Edited)
Discussion Starter · #18 ·
Happy Saturday Folks !!!
Just completed the installation of the JDM Toyota Premium Horns.
Replaced the OEM Denso Horns which are at 108dB each with the JDM Toyota Premium Horns which are at 300dB and they are each 500Hz/400Hz providing a clean, clear, and more vibrant sound.
Purchased from Roger at www.HybridPit.com.
Below are some photos of this easy installation :
50883
The JDM Toyota Premium Horns :
50884
Instructions :
50885
Tools needed : Socket Wrench / 12mm Socket
50886
Begin by removing the Engine Room Cover via the 7 Plastic Push Pins :
50887
Removal of the OEM Denso Horns :
50888
Comparison of the OEM Denso Horns vs the JDM Toyota Premium Horns :
50889
Thank you Roger from
www.HYBRIDPIT.com here in Southern California for these !!!
50890
Have a great weekend !!!
- Rodney
Discussion Starter · #20 ·
It's definitely a beautiful Saturday in Southern California for another Modification !!!
The Luciole Rear Wiper Delete Plug from www.HYBRIDPIT.com is complete !!!
It is available here : Luciole Rear Wiper Delete Kit For Toyota Prius 2016 - 2021
This kit for the Prius is compatible with the Sienna
50891
The Rear Wiper Delete Kit :
50892
Removal of the Rear Wiper Arm assembly. Flip the cover to remove the 10mm bolt.
50893
Access the Wiper Motor Assembly through the Inside Rear Hatch :
50894
Remove the JBL Subwoofer Enclosure :
50895
The Rear Wiper Motor Assembly. Remove the 3 - 10mm bolts and disconnect the electrical connection :
50896
The installation of the Rear Wiper Delete Kit is self explanatory. Here are the finished results !!!
50897
50898
Overall, I am very pleased with this product from www.HYBRIDPIT.com.
The rear wipers tend to collect debris, leave a trail on the window, and really only clean a fraction of the window so ... it was deleted !!!
Happy Modding Folks !!!
- Rodney
1 - 20 of 309 Posts
