going to remove the old t-belt in the next day or so, so far I already removed the engine mount, mounting bracket and drive belt. Just got the crankshaft holder in the mail today.
before I start the next phase, just wanted to make sure I understand the steps correctly. watched numerous videos over and over again.
1. align all three (front cam, rear cam and crank pulley) timing points to TDC
2. rotate crankshaft 60 degree BTDC, counter-clock wise
3. loosen tensioner for easier t-belt removal, then remove t-belt
4. the rear cam sprocket might rotate a little during step 3, but that's fine.
after replacing wp, seals but before installing new t-belt
align all three points to TDC again (they are no longer TDC after step 2 above), then proceed with t-belt install.
Are the above high level steps correct? I'm sure will have more detail questions later on.... thanks
