1 - 18 of 18 Posts
Does anyone know if 235/60/r18 wild peaks will fit on a stock 2014 LE AWD that is not lifted? Looking for better snow /forest svc road tires and have concerns about the JOR and traxda lifts since so many people seem to have cv axle issues.
If it's the same tire size then why wouldn't it?
I have 245/60r18 falken wildpeak AT on my Subaru Ascent. Same size as the OE and there is no issues. So I suspect you shouldn't either if they have that size
I only have 17" rims so I can't say but I already have snow tires (toyo gs5i) on my van and I have no issues either. Same size as recommended by the door jam.
I’m running 245/55R19 Blizzak tires right now, which are half an inch in diameter larger than the size you listed and 0.3” wider on highlander 9.5” wide wheels (35 offset) and they barely rubbed a little tiny bit on the plastic in the front wheel wells halfway between straight and full lock. I took a heat gun to the plastic and they no longer rub.
I am sure the size you show will fit without rubbing. The size I am running seems to be close to the max as far as diameter goes without major modifications and without going to a smaller offset)
Here are some images for reference:
Tire Wheel Automotive tire Tread Synthetic rubber
Automotive tire Grey Tread Synthetic rubber Rim
Automotive tire Motor vehicle Automotive lighting Bicycle part Fender
This is the rubbing I mentioned, on the rear of the front fenders.
Tire Wheel Automotive tire Hood Tread
Tire Wheel Vehicle Car Automotive lighting
2020 Sienna LE
Sort of off topic, I see from your pics its still pretty green where you are. Mind if I ask why you put your snows on so early?
Lol. So I had a set of worn Yokohamas on the original SE wheels which became extremely sketchy in the rain. I found this set of wheels and tires in York, PA for $450 and couldn’t pass up. I agree that it’s a bit premature for Blizzaks but it’s better than crashing in the rain 🤣
Temperatures here have already started to drop into the mid 30s at night so it’s just a matter of time anyway.
Mine was $100 ! 😂🤣😂 All four, no patches
11/32, toyo gs5i. They are good for the money. Made in 2018, so I have 2-3 yrs left. I want to max out my purchase. I'll let it ride till March. Then go back to my Michelin defender HT for the summer,. On my second set of 5 spoke LE rims.
Talking about falken wildpeak AT, I bought a used set for $250/4, 8-9/32. Better than my out going falken oe that's down to 4/32. I didn't feel like I wanted to spend $1000 at the moment. It'll last me another 3-4 yr before I have to look again.
$100. Wow, now that’s a bang for the buck.
I was after a set of 19s though, in keeping with the SE theme. Initially because I wanted to install them on the SE rims but I like the five spokes better now I think.
So you need rims or just tires?
I'm on the Subaru forum I am seeing these but they may be too big.
Also, the venza rims look nice. I saw this van while driving around last summer.
Wheel Tire Car Automotive tail & brake light Vehicle
Discussion Starter · #14 ·
I found that the local les schwab dealers are carrying wildpeak a/t trails in 235/55/18 - standard size for 2014 AWD. I'm not sure what the difference is between a/t trails and the AT3 though. I'm planning to replace my winter studded tires with these and run these year round instead.
Sorry for brief OT: is there a confirmed-reliable 2" lift kit for my 2013 Sienna AWD? What is the "CV axle issue" to which you refer? TX!
1 - 18 of 18 Posts
