2004 Sienna AWD XLE
I have been trying to understand why my Sienna gets poor mileage no matter how conservatively I drive. The low can be as low as 13 mpg when I am doing only short city trips, and the best has been ~ 22 on mostly highway trips up to the ski area.
I recently started watching the tach while driving to see where the torque converter lockup is engaging. As far as I can tell, it only locks up when cruising at speeds of 56 mph or over. At no time does it lock up below 56 mph. Since a large part of my driving is in the city, in the 35-55 mph range where getting rid of torque converter losses would make a big difference, I am trying to track down whether there is a problem with my sienna, or some way to get it to lockup at lower speeds.
Since my last fill up, I have been making a real effort to drive such that the lockup occurs in as much of my drive as possible, and had traffic allowing that on my trip yesterday to the mountain. I have seen as a result, about a 3 mph increase in mileage on the mpg avg the car gauge shows me. So I really would like to make the lockup work better at lower speeds.
I found this link from SiennaChat for this van which lists shift and lockup speeds:
https://www.siennachat.com/attachments/shifts-pdf.893/
It says that the lockup in 5th gear should occur at 40-44 mph, as opposed to the 56mph that I am seeing on my van. Surprisingly, the lockup speed for lower gears is higher, 65-68 mph for 4th, and 47 mph for 3rd gear. Or is this bad data? Lockup at lower speeds/gears would make great sense for mileage when climbing the long hill to the mountain.
If this is true, what would be likely causes for my van waiting till 56 mph before lockup. It could be the input speed sensor giving low readings, which would affect all the lockup speeds, which might also affect the shift speeds, but maybe the shift speeds are controlled by the output speed sensor. The shift speeds seem reasonable.
I have checked for codes, and found none. Trans fluid was flushed till clear red when I bought the van a couple years ago.
Any help learning more about possible reasons for the seeming lack of lower speed lockup would be appreciated.
