What are your thoughts about the Idemetsu TLS, (type iv) ? Or even the CASTROL trans max import stuffif you can find it, I have been using Mobile ATF 3309 (which meets the T-IV spec) for the last 15 years. Works perfectly and is usually less expensive than Toyota. I would not hesitate to use Aisin as DC_Dave recommends above. Aisin made the transmission in the Sienna.
I have no experience with either, so I don't have an opinion on them.What are your thoughts about the Idemetsu TLS, (type iv) ? Or even the CASTROL trans max import stuff
Yeah, I just ordered 12 qts of Toyota type iv. A couple of months ago, I put WS in it, and I was desperate and the only thing I had was valvoline maxlife multi vehicle. So now I just want to put the right fluid in and be done with itIn regards to the opening statement, reviews aren’t mixed for Toyota type IV fluid. Save money somewhere else.
Sixto
‘04 LE FWD 207K miles
I'll throw in my experience for what it is worth: I have been towing a small pop up (2100lbs) for about the last 75,000 miles with my 2006 LE FWD, now with 195,000 on it. I have drained and refilled the Trans regularly. Once I started towing I noticed that my trans fluid was quickly turning brown. I assumed it was gettiing too hot with the towing. I started using Royal Purple due to it getting good reviews regarding tolerating higher temps. Since I made the swich, about 50,000 miles ago, I never get the fluid turning that brown color. Now, full disclosure I did add a trans cooler as well, but I did use the Royal Purple for several seasons priot to putting on the cooler. Trans still doing well, smooth shifts, no issues with towing.I used Toyota T-IV transmission fluid in the beginning, then switched to Castrol Transmax Import Multi-Vehicle Automatic Transmission Fluid (synthetic) later. No issue so far with 231k miles on my 06 XLE FWD.
Good luck with the fluid, but at this age it may be the #1-2 and #2-3 shift solenoids? Ask me how I know this.....I need to do a service on my transmission. I’ve heard mixed reviews on what trans fluid to use Any guidance? It has a little bit of an upshift flare. 2006 toyota sienna LE FWD
Did you replace the solenoids in your van by yourself?Ask me how I know this.....
