Posting some TSBs (Technical Service Bulletins) I happen to have collected during my years of Sienna ownership...
This one is for certain Siennas where the MIL (malfunction indicator light/lamp... warning light) comes on in the dashboard and an OBDII-scanner returns the codes of DTC (diagnostic trouble codes) P0031, P0051, P2238, and/or P2241.
TSBs are not necessarily official "recalls". They are a "courtesy" Toyota factory-authorized warranty repair for certain designated vehicles that may or may not be affected by the noted issues and problems. Remember, an authorized Toyota service facility has to verify your particular vehicle is both ELIGIBLE AND AFFECTED (you might be one, but not the other) before any prescribed repair is attempted and covered under the warranty provisions. Some of the revised warranty terms for certain TSBs may extend or modify the warranty period and provisions for the original factory warranty. Read the details.
These may or may not apply to your Sienna. Please read the details and also verify with Toyota or an authorized Toyota dealer if there have been any updates/revisions for this problem. Many of these are "old" and probably have been corrected on newer model years. If you have an older Sienna (2004+), or you are not its original owner, the TSB may have already been performed. You can ask a Toyota service department to check your VIN record to see if the TSB is applicable, and if it was previously performed on your vehicle.
I personally do not have any additional info. Some affected me, some did not, and others were just interesting...
Please share any details of your relevant experience for the future benefit of others.
YMMV.
Good Luck!!
Has anyone actually had their ECM Reset like this TSB states to do when getting the P2241 code? I just got the P2241 code today and I have since reset the code with my OBD2 scanner. But if it keeps coming back then I am wondering if I can just get a new one by Denso and replace and forget it or do I need to also have this ECM reset done? Thanks.
Just a follow up in case it might help someone. When I got this code I reset it with my code scanner then unplugged the front O2 sensor and put some silicone grease on the plug and plugged back in. Over 100 miles later the code has not come back on. So far so good.
