wegngis said:
Just made a deal over the phone (Craigslist) to purchase a used Curt 13256, plus wiring kit, for $90. The only thing about it is he said he's leaving the bolts on his van. Who knows why.
Perhaps the seller is keeping the bolts in, even without a hitch receiver, to fill the threaded inserts to prevent corrosion and keep the dirt out. I would.
wegngis said:
Am I missing anything super critical by not getting the official install kit?
Official install kit? Is there one? It would just be the six bolts and washers.
wegngis said:
I'd rather buy new bolts anyway since I don't like to torque metal bolts twice in this type of application. I figured I'd go down to the hardware store and get some case-hardened bolts anyway, along with any lock washers that might be necessary.
I have no problem with the idea of new bolts, but I don't expect that anything that can be found in a hardware store would even be as good as the stock bolts Toyota uses to put the Sienna together, let alone better. I would be more comfortable with re-using the original bolts than using new stuff from a hardware store, as long as the used ones were not visibly damaged. I realize that is not an option in this case, since the used ones are not available. Also, the hitch is not a Toyota part, so the bolts may not meet typical Toyota standards.
I don't think "
case hardened" is the term which is intended here, although more "hard" than the lowest grade of bolts would be desired. Harder bolts - a "higher" grade - than the basic hardware store stuff are probably appropriate, but too hard is not good and the Toyota hardware would be a
suitable grade. At a
guess, I would expect the OEM bolts to be ISO graded 10.9 (similar to SAE Grade 8 ) or higher, while basic hardware store stuff is typically 8.8 (similar to SAE Grade 5) and likely unsuitable.
If a dealer were to sell the bolts that come with the OEM hitch (which is supplied by Reese) at a trade price, or maybe even at MSRP (instead of the usual inflated-even-above-MSRP), my guess is that they would still be much more expensive than a near equivalent from a bolt store, but not so much money that it is worth the time to hunt for the generic replacement. If anyone knows the prices (of OEM from Toyota, OEM for the hitch from a hitch supply source, hardware store junk, and good non-OEM bolts from a hardware store or fastener supplier), I would be interested in hearing them.
