What to get in order to end up with 18" ball height
5.3K views 8 replies 5 participants last post by  jseyfert3
Can't give part numbers, only suggestions.
When the hitch is installed and the van is on level ground, measure from the ground to the TOP of the receiver hole.
Measure the height of the ball you will be using.
Add the two measurements, compare that with your desired 18", you will have the amount of rise you need in a drawbar.
