So, we have a new-to-us engine coming out of a 2010 Camry (I don't know what I'm going to have to swap over from the old engine yet, I know the water pump is the same).
In preparing for the job, we're trying to determine what we should change/freshen up while the engine is out and on the replacement engine. Car was in service until last month, rear end damage only. Runs and drives.
Please let me know what else you would replace while the engine/transmission/transfer/lower front suspension are out of the car? The '08 AWD is original front end and drivetrain.
Here are the thoughts so far, what do you think?:
- Engine
- All new Plugs
- Three new rear coils (We'll have 6 spares)
- Valve cover gaskets
- Re-seal timing cover?
- Should we do the water pump even if it looks good?.
- Transfer case (seep/leak at the RH bearing retainer vent, T-SB-0138-10).
- Replace RH Bearing Retainer Oil Seal No. 2
- Output seals?
- Other seals?
- CV Joint boots? (joints seem fine so far, boots are in good shape)
- Replace boots
- Front boot kits
- Moog clamps
- Replace boots
- Hubs
- Should we get new bearings pressed onto the hubs?
- Front suspension
- Stabilizer bar links
- Replace struts now? (KYB strut-plus)? Struts seem fine @ 153k, but might be getting to EOL.
- Moog strut mounts?
- Replace ball joints (we have them)
- Tie rod boots (we have them)
- Propeller shaft (seems fine)
- U-Joints or support bearings?
- Can always do this later if a problem arise
