1 - 16 of 16 Posts
When stopping if you can slow down gradually enough so that the Eco needle never bottoms out in the Charge section the van is just using the electric motor/generators to slow the van by charging the battery. If you brake hard enough to bottom out that needle the van is also using the standard friction brakes to slow down.
2021 LE
Wow, that's great information, thanks
2021 LE
Haha, and that's what I do most of the times, which means my brakes will last an awful long time
Oh, and if the battery is full you'll hear the engine rev when slowing down. The van is still using the motors to slow down but it is dumping the electricity into spinning the engine (with no fuel). You'll get this on long downhills as well when the battery fills up. Sounds weird but totally normal.
2021 LE
Discussion Starter · #7 ·
Ah, I see now. I always wondered what the hell that is
2021 LE
Discussion Starter · #8 ·
I was about to discuss that with my Dealership, I thought something wrong was with my transmission messing up the engine
I wish there was a separate indicator that defines regen brakes vs standard (friction) brakes. "Bottoming out" means maximized regen AND/or various degrees of standard braking. The left dial seems to have a lot of space for more information like RPM, AMPs generated/lost, Traction battery voltage, battery temperature. Am i asking too much ?
2021 LE
Discussion Starter · #14 ·
Why do you keep asking this question?
I realized that but it was too late then. Apologies. Moderators could merge the two threads. Thanks
When the needle bottoms out, does that mean it's still charging the battery, even if it's using the Friction Brakes?
Yes, it's just supplementing the regen braking with the friction brakes up to the point you lock them up (which may not be completely possible with anti-lock brakes) since at that point the wheels are no longer turning. But you are defeating the purpose if you routinely do this (Emergency braking aside).
1 - 16 of 16 Posts
