Has anyone replaced the window run channel (called a "glass run" in the service manual) in their Sienna?
Our front door windows are sticking, resulting in a nice "pop" whenever I open the window because the rubber grabs the window in it's closed position. I've tried cleaning and lightly lubricating the top of the run channel, but I think the rubber is just old and getting tacky ... so in my opinion it's time to replace the rubber.
The instructions seem simply enough in the manual -- remove door panel, remove window glass, then pull out and replace the "glass run".
My question is, should I lubricate the new run channel when I install it? Other car mfgs and internet guides suggest to coat the vertical sections of the run channel with silicone grease/paste or an equivalent. However I don't know if this is just a remedy for old rubber or if this is a standard factory install procedure.
I could not find a DIY thread anywhere ... has anyone done this on their Sienna?
Thanks. John
Thanks. John
