I just got my 25 AE Feb 27 and I live in Saskatoon, Canada. Winter here is -10c to -40c (14f to -40f). I don’t have any experience with summer fuel efficiency but maybe some members that do get cold temps can weigh in on the difference they get from summer to winter. So far on the divided highway (interstate) with a strong 60kmh tail wind I was getting 7.7l/100 at 119kmh at -10c.
We did a trip around the city yesterday with several stops and 30 or so Km on the highway going 109 or 99kmh. It averaged 9 ish for the day. It was -14 to -18 with a wind. Not great but likely 5 l/100km better than my ‘08 highlander v6.
I’m interested in the hybrid logic and how to control it a bit. What I’ve learned so far is that when the heat in the cabin is set to auto and temp to “Hi” the van will use the engine exclusively. It seems to make the engine work as hard as possible so it will produce as much heat as possible into coolant to give to the cabin. During this scenario it steadily charges the battery up to one bar from full. If on the highway going 109kmh it will start to use some battery but once you slow down to, in my case 60kmh, it will charge the battery again. Once I changed temp to 24c it started using the battery again.
Another theory I have is it will only charge the battery when it’s cold. It won’t use battery power until it’s warmed up. We park in our 5c garage and it seems to function normally from there. We parked outside in -16 for a couple hours so the battery got cold and it charged the battery to one bar from full then it stayed there for a while after the cabin got warm. So I wonder if it charges full then uses excess electricity to heat the battery to a certain temp before it starts draining?
Has anyone had luck controlling battery use with drive modes or some other trick?
