Anyone ever use or know of anyone to use the WPN R y pipe?
I installed a "J pipe" on my Acura TL when I had it, and it made a little change in exhaust note, and actually increased my mpg by 1. I was very impressed with the results. There was a ton of dyno results that proved it.
I was hoping this may have the same results for the sienna. I'm mostly just interested in increasing my mpgs.
Please keep us updated! What is your plan with the gaskets? Are the holes on the bung slightly oversized (not tight to bolt)? Cost and link?
Discussion Starter #4 (Edited)
Its installed. I had my local shop do it. He said it was a tight fit, but it fit pretty well. The quality seemed really nice. I purchased 1998-2016 Sienna API exhaust gaskets for replacements. It did come with bolt hardware and exhaust doughnut gasket, but you'll need the API gasket. Pipe was only $228 and came in less than a week. As i mentioned i hope to get similar results like I did with my TL. I report back after I get some miles on it.
Weapon R 11-17 Toyota Sienna 3.5L 2-Piece Racing Y-Pipe (Off Road Use ONLY), 953-203-104 – RCA Garage
I personally would delete the y pipe and go for true dual exhaust through an x pipe it will scavenge better and will have substantially better performance. I’m currently am doing this on my 15 as well as komotec headers and full cat delete
