After diagnosing some overheating issues I've determined that I have a problematic head-gasket.
I'm neither experienced or inexperienced at DIY wrenching, I've owned an E46 (BMW 330Ci) for the last 15 years and have replaced Cooling System, Crankcase ventilation System, Valve Cover Gaskets, Oil Filter housing Gasket, Oxygen Sensors and Control Arm Bushings.
I prepared by studying youtube videos for over 10 hours:
(Document Link - feel free to comment on doc if you are compelled to)
It Begins:
I pull sparkplug in Cylinder 2, Notice it is oily. Not what this much oil in cylinder indicates...
My First Mistake: I bought an E Torx 6, But I think these are actually E Torx 4, I started on the right one and kinda rounded it off... (Edit.. Got a Set of E Torx 4-8, they are E6!)
Intake off
Protip: Put a towel underneath where you might drop a bolt. Also, if you can't see the bolt/nut you're unscrewing: close your eyes and channel focus.
Rear of intake manifold - Passenger Side - If you know you know...
Cylinder 1 looks to be 'steam cleaned' as expected. (coolant leaking into it and getting combusted)
Day 1 comes to a troubling end, with the 2 long bolts, and the one connecting to the body AND the one near timing being on very tight. Soaking overnight with WD40. Thoughts and Prayers plz
It Begins:
Intake off
