Wanted to see if we could get an official thread going just about wheels. I'm on the younger side when it comes to van owners, and I wanted to spruce it up with just a pinch of style. Looking for inspiration. Please post up your beautiful rides!
Did you have any rubbing with the 235/65 tire size?2022 Toyota Sienna Limited AWD Hybrid Stock wheels have a Chrome Cap over Black aluminum.
I had one shop quote me $400 for Rhino black aluminum wheels and when I started looking more in depth at my wheels, I realize the chrome caps could come off. It took me using to pry bars and being careful not to scratch them. The pry bars that I used were 3 foot that I use for construction.
I have not been too concerned with removing industrial grade adhesive from the hubcaps due to my sienna been on the trails more often than not.
I plan on checking with a powder coating company on what temperatures would be safe to apply heat from a heat gun to remove it in the future.
Any rubbing? Does the sliding door clear the wheel?View attachment 63727
TSW Pescara 18x8.5 +40 bronze
About to buy the same wheels. Any rubbing or issues so far? Would love to see more pics if you got them!I waited almost a year for my XSE. Picked it up last week and got the wheels on today! Still need to tint the front windows and finish the chrome delete.
20x8.5 Enkei w/ 255/45 Michelins
I’ve been scouring the forums for this exact questionHas anyone fitted 20x9.5 +35-36 wheels on this gen sienna?
I ordered Velox rims through Costco for my snow tires. They came with center bore adapters and lug nuts. The lug nuts did have the collar on them like the factory ones and the rims were drilled out with larger holes to accommodate them so you get the same thread engagement as the factory set-up. I am super happy with them. The rims I ordered for my summer tires do not have this and I am bummed that I did not order the Velox wheels first or I would have bought a second set of Velox.I had the same problem with my XM6 wheels. I had asked if anyone else was having the same problem, but no responses, I assume it was just me. Ended up installing new ARP studs... Unfortunately, ARP studs are extra long, so I had cut them down.
Brain fart... ignore this....On the stock wheels, are there any aftermarket option for spline style lug nuts? I have no preference between open or closed ended
What size wheel and offset? What size tires?For you guys that prefers the meaty look while using the stock tires …did the measurements for you already in terms of fitment. No rub a dub dub…hope this helps with wheel and tire fitment with our cars.
Are you on OEM suspension?Raceline 401B Aero
17x8 with 40 mm offset
Falken Wildpeak A/T Trail
235/65 R17
Before and after…
View attachment 62696 View attachment 62697
Any updates to this brother? Did you find a light wheel?Is there a consensus on the best performance wheels in terms of weight savings?
If I'm going to upgrade wheels, figure I would go for lighter and high-quality tires.
Haven't really seen anything in the 20 inch range for weight savings. Looks like probably have to go down to 19inch wheels or maybe go to 235/55/20 vs 235/50/20?
Sorry to bring this post back, but i have a question about the longer wheel stud? Did you mention the over all total length is 50mm from the base to the tip of the stud? Not the stud threads? I just got the 50mm total length studs and is still seem short to me? I am going to install the new 21" lexus wheels, but stock studs not long enough and want to replace with a longer studs, i hope the one i got is long enoughI got the longer wheel studs installed on the front wheels, rear wheels will be later this week. As I mentioned in a previous post, I didn't like that the wheel nuts with my enkei wheels only engaged 10mm (I would guess most aftermarket wheels have this issue because they mostly use cone nuts and not factory style shank nuts, and most people don't know because they get installed by a shop!).
The only reputable studs I could find were the ARP 100-7715, as was mentioned by BenG. Unfortunately the stud length on the arp's is 65mm and they are too long. I found that 15mm needs to be taken off the arp's for a total stud length of 50mm (factory are 40mm). Being 50mm, they are short enough to be installed without removing the hub, and have 20mm of thread engagement now. I had my father machine them down on a lathe for me, for a better clean look. For installing the new studs, I used one of the factory lug nuts, with a shallow 1/2" drive socket as a spacer, to seat the new studs. On the front wheels, only the two caliper bracket bolts need removed, and the brake line-to-strut bolt. Fairly easy job, longest part was getting the hardware measurements and cutting to size.
View attachment 66089 View attachment 66090 View attachment 66091 View attachment 66093 View attachment 66092
