Okay, lets start this off. I've got some 60 pictures
I'd probably start by finding a level surface you can work on the vehicle, and jack it up. I used the front center jack point, as outlined in the above post, and placed jackstands in the two front jacking points, leaving the front tires just off the ground when lowered onto the jackstands. Remove the front passenger tire, and the plastic divider between it and the engine. This plastic divider has two screws and a plastic clip, the latter of which was jammed and broke on me. I need a new one but don't have the PN for it yet. Once you get this off, you have access to the drive belt from below.
Stick a 14 mm wrench on the tensioner pulley and twist it counter-clockwise to loosen the belt. There's a hole on the bottom once you fully loose the belt that fits a 5 mm hex key nicely. This holds the tensioner pulley, so you can remove the wrench. Now you can easily slide the belt off without trying to hold the pulley as you do so.
Once the belt is clear, if you aren't sure if the water pump is indeed your issue, you can now freely spin the water pump pulley. Try to wiggle it side to side. If it doesn't turn easily, or has play when you wiggle it side to side, it's definitely not good.
Go back to the top, and remove the AC line bracket screw using a 10 mm socket and a long extension.
There's two black wires, one to the engine, and another tee'd off this that runs to the back. I'd remove both of these wires. You can leave them hanging from the upper left mount. There's a black connector on the ABS dohickey on the left. Pull the gray part of the plug up, it comes up about 1/2" or so, then the plug can be pulled straight back to remove. Just let it chill out there. It just needs to move down slightly to get a bolt out in a second.
The torque mount, the big black thingy, needs to be loosened at the engine bay side. Give it a few turns, but no need to remove it entirely.
Remove the upper engine mount bracket. Start by removing the bolt on the torque mount. Then completely loosen the three bolts on the upper bracket. The top one also bolts down a small black bracket that goes to the right, where it's held in place with two nuts. Remove the two nuts and the small black bracket. Then remove the one bolt that holds the small aluminum bracket that's bolted under the black bracket by the the two nuts. Now slide the upper engine mount forward to clear the torque mount bracket and remove. I left the bolts in so they didn't wander or get mixed up. I also stuck the two nuts back on the engine mount bracket so they didn't get lost, and threaded the single bolt holding the small aluminum bracket back into the engine for the same reason. (in some pictures the small black and aluminum brackets are missing, cause I put the bracket back in and forgot them, then had to remove the one bolt so I could re-install them)
Remove the 5 bolts holding the lower engine mount bracket. Leave the pictured bolt for last, this is the troublesome one. Once the first four are out, noting where they go cause there are several different lengths, remove the 5th bolt. This will hit the AC lines. Once it's free, make sure the bracket is loose, then
gently pull the AC lines towards the side of the engine bay while wiggling the engine bracket to the side and towards the rear of the van. You need to get the bolt to the left, and then the right side of the bolt can wiggle free under whatever it's stuck on as you wiggle and twist the bracket towards the back of the vehicle. Once the bolt comes free on the right side, it'll lift up and out. Removed picture shows the 5th bolt. Once out, I put the other four bolts into the holes so I'd know where they went and set this off to the side.
Should now look more or less like this.
Remove the tensioner and idler pulleys. The tensioner pulley is easiest to remove from below.
This is a left-hand threaded bolt, so turn it clockwise to remove it!!! In the below picture it's already removed. Then remove the idler pulley. This may be easier to reach from the top, but can also be removed from below as shown. This is a normal bolt, turn it counter-clockwise to remove. Set both pulleys off to the side, and leave the bolts and dust covers with them in the proper orientation and position. The tensioner has only one dust cover, the orientation of which matters. The idler pulley has two, the orientation of which doesn't matter, but they are two different sizes, one of which is on one side, the other on the other side. Don't mix them up (the FSM lists sizes and which one goes where if they do get mixed up).
Drain the coolant. Place a drain pan of some sort under the center of the van. Look behind the radiator at the base. There's a plastic drain cock. Loosen this, there's no need to remove it completely. Coolant will start to drain. It
almost lines up with the hole in the splash guard, but some got on the guard and drained out of holes on the sides. Take note, some extra containers or rags may be useful.
Once drained, remove the clamp on the radiator hose, then slide the hose off the metal tube. I was able to grab the hose and twist it to break it free, then it slide off easily. Set this off to the side. I'd recommend stuffing a rag in the opening to avoid junk getting in it like what happened with mine.
Remove the two nuts holding the metal tube onto the thermostat housing with a 10 mm socket, extension, and ratchet. The top back nut is fun to re-install later...
When installing, be sure to not install the idler pulley first like I did, or you can't get the tube on and need to remove the pulley again.
Remove the thermostat. I grabbed it with a pliers cause it was stuck, which bent it, but I was replacing it anyway, so it didn't matter.
When reinstalling, be sure the jiggler valve is up (the little loose metal piece near the top).
Limited to 20 pictures per post, so breaking here.
