Our 12'XLE flashed the TPMS error this morning. Tire pressure is good and I am thinking that its the TPMS failing. In that case its been a good run as we got almost 13 years (3 months shy) out of the OEM ones.
Luckily I ordered 4 sensors from AE last month which I can now swap and with Techstream coding should not be an issue. I checked around and the shops want anywhere from 125 to 250 to reprogram these plus the cost of swapping them out at $20-25/wheel.
Question:
Any other advice/recommendations for the swap.
Thanks
Question:
- Are these the ID's (ACFED098 / ACFEEC38 / ACFED2C8 / ACFEE418) that will need to be entered? Pic attached for reference
- Can I code in the new sensors, using TS, ahead of time and then just have the tire shop swap out the old ones
- If yes, then will programming in the new ones cause the TPMS error to stay!!
- I am thinking yes since they don't have any pressure to measure which should be gone after the swap and a short drive
- If Techstream is not the right programming tool, do any auto shops have TPMS loaners?
Thanks
