How to route wires through firewall on 2008 Sienna?
13K views 7 replies 6 participants last post by  dlace64
I'm installing a brake controller on my 2008 sienna and was just wondering if anyone has any suggestions on how to run the wiring through the firewall. Thanks!
#2 ·
I ran mine through the boot near the steering column. There was a small closed off tube coming off of the boot and I used that. It is a pain though because it is so far back under the wiper cowling. I was able to poke a metal rod through from the inside and attach the wire to it and pull it back through.
#3 ·
I used an existing boot around an opening, like p220sigman. I used one toward the passenger side; I just found an empty area in it and poked a hole through... having first checked that the interior side would be accessible.
#5 ·
Thanks for the input! I finally got around to doing this and was able to get it through the boot on the driver's side. It took some determination - its really tight in there. I wish i would have thought of the wire coat hanger trick.
#6 ·
Just finished mine yesterday. Not sure if it's any different than what the other posters are saying but I used the same harness that the hood release goes through. There is a spare nipple that you can snip off the top and push the wires through. Followed the hood release cable around to the vicinity of the battery.
#8 ·
same here. trying to install a siren chirper on my 2015 SE.. but i need to find out how to route the wires through the firewall. i really dont want to drill a hole or anything. i wish Toyota had made a designator solely for hooking and wiring things up..
