Has anybody had any issues or thoughts on the 4-cylinder hybrid being underpowered?
This is exactly the situation i face everytime i go in and out of LA.How much weight in the car, what grade and for how long?
I say do another test drive, but with ear plugs this time. The droning noise makes you think it is in pain, but it is really not. I thought this was the case in my early ownership. I have since learned to ignore droning noise and keep at it on the gas pedal.
May be it is under power for what you need, but you will have to be fully loaded going up 5 -7 % grade for over a mile. (My uneducated guess).
245 HP is combined. Independently, the A25A-FXS outputs 176 HP, this means the Hybrid system is adding 69 HP on top of that. However, the Hybrid system isn’t always on, especially climbing when it’s being recharged.It's a 245HP minivan that drives like a 245HP minivan.
In most cases, there is some reserve in the battery that can be used resulting in the 245 hp pretty much is available most of the time. It is unlikely that 245 hp is needed continuously. The electric motor actually is rated at 179 hp I believe. However, you cannot simply add the two hp ratings because the hp varies with respect to rpm. Both power sources do not have the same power curve, resulting in a bit lower hp rating.245 HP is combined. Independently, the A25A-FXS outputs 176 HP, this means the Hybrid system is adding 69 HP on top of that. However, the Hybrid system isn’t always on, especially climbing when it’s being recharged.
I am almost certain that the A25A-FXS version in the Sienna and the Highlanders is rated for 186 hp rather than 176.245 HP is combined. Independently, the A25A-FXS outputs 176 HP, this means the Hybrid system is adding 69 HP on top of that. However, the Hybrid system isn’t always on, especially climbing when it’s being recharged.
You're right but I think there are caveats, nuance, to it.245 HP is combined. Independently, the A25A-FXS outputs 176 HP, this means the Hybrid system is adding 69 HP on top of that. However, the Hybrid system isn’t always on, especially climbing when it’s being recharged.
I am guessing you were climbing the western slope of Vail pass? It's supposed to be steeper than the east slope.You're right but I think there are caveats, nuance, to it.
I mentioned this earlier already but here it is anyways.
Only time I had run out of battery so far was going up Vail pass fully loaded. That too was not continuous. Battery was down to last bar, RPMs maxed out around 5500. I felt the electric motors cutting in and out every few seconds. It didn't have any impact on the speed. I was still the fastest going 65 on 55 speed limit at that point in time. This was during our 1M0/10K miles coast to coast trip within DC, Seattle and Las Vegas Triangle visiting various national parks. We drove thru a lot of elevations with about 10+ speed limit without any issues.
That explains why the engine RPM is very high when climbing a hill. Even though you might not be flooring it, you might be running the engine at 100% power. If you do floor it, then you only have 245 horsepower available for a short amount of time until your battery power is drained.245 HP is combined. Independently, the A25A-FXS outputs 176 HP, this means the Hybrid system is adding 69 HP on top of that. However, the Hybrid system isn’t always on, especially climbing when it’s being recharged.
Yeah, we were going east towards Denver from Moab.I am guessing you were climbing the western slope of Vail pass? It's supposed to be steeper than the east slope.
I don’t know if you’re asking me (I responded awhile ago to this thread), but yeah. It’s a 19.5’ Yamaha jet boat, just shy of 3K# on the trailer (trailer has brakes). It does fine, even going up central PA mountains. I do pay attention to GCWR, so I don’t have a lot of people or too much weight in the van when doing it.You pull your boat with a sienna 4 cylinder ?? Hybrid
I still can't get over the fact that a 4-cyl hybrid Sienna can lug around a 5,000+ lb. of 4-cyl hybrid SiennaYou pull your boat with a sienna 4 cylinder ?? Hybrid
I don't drive fast myself, but I do often notice other Gen4 Siennas barrel past me @ 95 mph+, so it feels like I am standing stillI constantly drive my 2021 Toyota Sienna Hybrid at speeds well over 100 MPH, not just on one-off occasions but regularly on dozens of different trips and even during normal everyday driving. Honestly, I don’t get the complaints about it being “underpowered”.
On my most recent trip, I drove from NYC to West Virginia to New Orleans, keeping speeds of 100 MPH or more for most of the way. The best part was driving down the whole state of Mississippi, it legitimately felt like driving on the German Autobahn most of the time. I was cruising at 115 MPH for long stretches, but there were also times when I had to slow down and then speed back up to 115. Even with a fully loaded car (im estimating 1,300 lbs of passengers and luggage, just shy of the 1,420 lb max payload), the Sienna handled it perfectly. Also worth noting that I got around 25 MPG for this whole trip.
The car does seem to have a governor that cuts power around 117 MPH. I maxed out at 118 MPH (116 MPH GPS-indicated).
In my experience, this hybrid 4-cylinder has plenty of power. Maybe not as much as the previous year Sienna’s V6, but still more than adequate. Again this is my opinion.
The droning engine sound and the rubbery, shift-less acceleration may produce the sensation of the engine struggling with the load, but, as well all know, the van has absolutely no problems picking up speed. With the exception perhaps of driving up a steep grade for a couple of dozen miles when the battery doesn't have the chance to recoup some energy from regen deceleration.I am thinking the dudes that say power sucks are the dudes not used to using 100% of the pedal. These eCVT’s are kinda weird. To get moving, your foot has to be on the floor, and if in sport mode, the van does a decent job moving right then and there.
Whereas not in sport mode, there is a feeling of hesitancy for the van to go into full throttle mode and start moving. It isn’t much, but it’s noticeable to me. Not a thing in sport mode imo, it feels fine but mpg’s do take a hit (as expected).
Okay I must admit this vehicle drives very well and has ample powerMy 2018 Sienna was the fastest vehicle I’ve owned since my 1969 Plymouth Road Runner. Arguably, it had more power than needed. My 24 Sienna XSE isn’t as responsive but adequate. The biggest difference is above 75 mph and headwinds above 25 mph on the interstate. I prefer the new Sienna XSE because it drives more planted, and not as bouncy at faster speeds. I don’t know if the difference is the TNGY Platform or the XSE suspension.
Some time I really have to laugh about post in this forum.A word to the post about using 100% of the pedal - yes. You use 100% of the pedal travel in this car. Most vehicles you never need to press it more than 75% because once your engine is producing max torque it doesn't really matter anyway, you can cram it to the floor but it's not going to do much more. Not so with the Sienna. You get a linear and noticeable change in response through the entirety of the pedal travel.
