I just got done replacing my cv axles along with rack and pinion, lower control arms, motor mounts, tre's, ball joints, and installed a 3.5" lift. Prior to this work my TRAC Off, VSC, and ABS lights have been on for years, but now I've added the tire pressure light, brake light, and the speedometer doesn't work. Anyone ever encounter this? Can you point me in a troubleshooting direction to narrow down the problem? Transmission speed sensor, wheel speed sensor, CV Axles not installed properly....?
I DID pull the front wheel speed sensors and cleaned the debris off of them hoping it would be that simple, but..... it was not
