Hello
I have a 2009 Toyota Sienna LE with 14000 miles and this is what it's happening :
When the car is stopped (for example at a red light, gear in D position) i feel a uncommon vibration on the steering wheel (when idling at 700rpm) and it "migrates" on the interior door panels (when idling at 600-650rpm)
Also when powerbraking and getting the rpms to around 1400 rpms the "vibration/resonance" migrates under the front seat and it's strong.
In N position the vibration diminishes 90% but i can still feel vibrations, just far away...
When the car is moving 99% of people wouldn't sense the vibration, i can but very very slightly.
Car is under warranty and 3 of the dealers in my town told me it was "normal". Just the "Toyota way"
This engine is the 3.5-liter 2GR-FE V6, the same in the Lexus RX350 and i've noticed in Lexus forums that the RX350 has the exact same problem and they haven't fixed it either...
I've test driven another Sienna 2009 with 35K miles and it doesn't vibrate like this at all!
4th dealer i saw, took out all the engine mounts, inspected them (ok) and told me that the engine block was tilted a little bit to one side, he put everything back and installed the engine with the right angle but nothing improved. They also found a small vacuum leak that they fixed. (3.5 hrs under warranty luckily...)
I called Toyota HQ and they told me to speak to the service manager and ask him to use their special technical support line that only services managers can access.
I did that and he told me that he will call me back, i am still waiting.
I know it's not the engine mounts, because when i rev'd it up and down while powerbraking, the engine block is really solid, no funky movements.
Someone suggested the transmission? it does hunts for gears sometimes like it's reported on other threads...
maybe something else?
What can be doing this? I am really desperate...
thanks for the help
thanks for the help
