Has anyone added a spare tire to a van not equipped with one? Just looking at the parts diagram, it seems like it's gonna be more the the $75 it was as an option.
Nice idea, and a tidy solution. If it had been an option at time of purchase I would have gone for it.Somewhere in the neighborhood of $1,500
What do you think the parts and spare cost?
Too pricey IMONice idea, and a tidy solution.
Exactly what I was going to suggest. Smaller is cheaper so get a 17" as long as the OD is the same, get a jack off Amazon for less than $50 delivered right to your door and your done.FWIW, a used tire shop around the corner from me got me a used tire and rim for $120. I am not going to complain about saving money, but the reason I went there is that it was easy to talk to them. I knew nothing about tires or rims. I pretty much pulled in, he took a quick look, and called me a couple of weeks after when he had found it. It is a spare that I hope I have to never use it. I don't care about asthetics as long as the tire looks decent and that it can go a few hundred miles. They even put it on for me to take a test drive, and than put the newer on back on.
Btw, any of 17, 18 or 20 inches ones should work. 17s are on LE and XLEs. Plat AWDs have 18.
Don't forget the jack and a tire wrench.
If I have to do it again, I would do a 17Incher. It will be relatively easy to deflate and shoe-in sideways behind 3rd row. I also bought another cheapy airpump as a back up to inflate the spare wheel.
I'm just going to get this kit. It comes neatly in a carrying case. The ease of just "putting the bag" in the trunk when you are busy packing for a a long road trip is worth it for me.I was going to buy a full size spare to put it in the trunk for long road trips only but that will cost about $350 to $400 on tirerack.com. having a hard time finding cheap steel rims in that size.
i might just go with this kit Complete Spare Tire Kit 2021-22 Toyota Sienna, Compact | Modern Spare with shipping for about 500. unless someone here have another suggestion.
You're forgetting the need to replace the entire rear drivers-side interior panel.From the PDFs that were posted earlier, we need the "Spare Wheel Carrier Assy" which runs about $235 online. The OEM Toyota wheel is about $245 online. Add another $100 for the tire plus mounting and balancing, lug nuts, and new label and it's maybe $600 in parts.
The kit indicates that it includes the "Quarter Panel Trim Assy" and "Spare Wheel Cover". It has to be ordered with the correct color of the van interior. Are you saying there are more panels that need to be replaced than just what's in the kit?You're forgetting the need to replace the entire rear drivers-side interior panel.
Show us the kit when you got it.I'm just going to get this kit. It comes neatly in a carrying case. The ease of just "putting the bag" in the trunk when you are busy packing for a a long road trip is worth it for me.
I got 99 problems but the spare aint one.....
I'm confused. You the first person to reply to this thread in post 2 stating your dealer screwed up your order and had to pay for everything. You did paste the thread below when you responded so if anyone should know what parts were needed wouldnt you know? Not trying to be an A hole, just not sure why you dont know what all is involved if you had everything switched over.I haven't looked at the kit. Perhaps you're correct. The one just posted above by Cascadia doesn't seem to have any interior panels, though. Was mostly replying to your post which only seemed to mention mounting hardware and tire details.
I know exactly what's involved. There was no kit. There were individual components ordered and installed. There were tire components. There were mounting components. There were jack and lug wrench components, and a new door for the 12V battery area. There was also an entire rear interior panel, the most expensive part of the change. If there's any misunderstanding here, it's me not knowing what you're referring to by a "kit." Does this help?Not trying to be an A hole, just not sure why you dont know what all is involved if you had everything switched over.
The one I ordered is just the spare tire and all the tools needed to change a flat tire. It will probably sit in my garage for 90% of the time and will only be in the van for road trips. This is more than adequate for my needs.I haven't looked at the kit. Perhaps you're correct. The one just posted above by Cascadia doesn't seem to have any interior panels, though. Was mostly replying to your post which only seemed to mention mounting hardware and tire details.
Yes it is.
I would think you could do anything, but it may not match the rest of your interior since that was an option on limited models and up if I remember rightI have an XSE without the 3rd row sun shade. Could I add the shade if I opted to get the spare carrier assembly that has the shade? Does the shade come included? Or does anyone happen to know the part number for it? I figure this would be a good time to add it (at least on the driver side. I’ll worry about the passenger side later lol).
Looks like it. I bet the actual shade and hook for it are separate thoughToyota Sienna Spare Tire Carrier. NEUTRAL WARM GRAY - 5190008070C3 | Conicelli Toyota, Springfield PA
Spare Tire Carrier. NEUTRAL WARM GRAY. Toyota Sienna. Genuine Toyota Part - 5190008070C3 (51900-08070-C3). Ships from Conicelli Toyota, Springfield PAparts.conicellitoyotaofspringfield.com
Would that give the rear sunshade?
