81 - 84 of 84 Posts
All, Thought I would post this info as I too am looking for info on stiffer and slightly higher springs. Below is the Specs on Gen2 & Gen3 springs. Identical save Gen3 is 5/8in taller. Sources from Sienna Chat feeds, RockAuto, and MOOG web sites.
Sienna Gen2 & GEN3 Stock Coil Specifications (rear) MOOG 81409
End 1 TypeSquared
End 2 TypeTangential
Relaxed Length (IN)
14.19​
Relaxed Length (MM)
360.36​
Gen3 Relaxed Length (ID) 5/8in taller
14.815
Compressed Length (IN)
10​
Outside Diameter (IN)
5.89​
Inside Diameter (IN)
4.57​
Spring Rate (PP)
350​
Spring TypeConstant Rate
Spring ColorBlack
Wire Diameter (IN)
0.66​
Wire Diameter (MM)
16.66​
Here are the specs of the 99-03 Odyssey Springs for those interested. Also sourced from RockAuto and MOOG Sienna Chat shows a 3in lift increase on Gen2, so I am guessing about a 2in lift on Gen3
2003 Odyssey MOOG 80661 Specifications
End 1 TypeSquared
Relaxed Length (IN)
14.06​
Relaxed Length (MM)
357.2​
11​
6.11​
4.66​
Spring Rate (PP)
442​
Spring ColorBlack
Wire Diameter (IN)
0.71​
Wire Diameter (MM)
18.2​
I am planning to try the cheaper dollar spring set found on RockAuto for 1999 Odyssey (to date $52) and seeing if this helps my sag/scrape issues and could allow for 4 bike tray hitch rack. if the empty ride is awful I can look at CCS building a variable rate spring
Hi Brett, this is a great find. Did you end up trying the Odyssey springs? I'm curious to hear how it worked out. Did you use the cheaper Mevotech springs or the Moog?
Thanks for posting this. I haven't had time to install my spacers yet and am interested in trying this option instead for the rear. This thread doesn't mention any unloaded ride quality issues on a 2nd gen so I'm assuming there's not a problem there. I notice the OD is slightly larger on the Odyssey springs. The springs fit pretty tight and I was wondering if there might be a fitment issue so I checked here and the 2nd and 3rd gen sienna rear insulators are the same so they should fit our 3rd gens no problem. When do you think you'll do the install? It'd be great to hear how it goes. If you're in no rush I might just order some and try it myself.
For anyone interested, front traxda spacers can be ordered by themselves for what seems to be a ridiculously low price. I ordered Traxda spacers 114.1 (rear for $65/each) and 104.6 (front $30/each ) and it came to $166 w/shipping. These are sold indivually so you have to buy 2 per 'axle'. I found and used JONDZ20 (something like that, it's easily found online) discount code and it's still active for 20% off. Also I'll be trying the KYB 'mobility' shocks. I was going to get the monroe's but I think the kyb's will pair better with the stiffer springs. I was kind of wondering if the geometry is the same and the Odyssey shocks could be used on the Sienna too.
Hi PepperZ, I'm on a similar path to you with my '15 XLE AWD. I'm curious if you've done these mods and how they are working out for you? Any tips, tricks, or pitfalls you can share? Thanks!
I did the odyssey spring swap. I used lesjofors springs from rockauto. They are made in Sweden, look to be good quality, and gave a 1.5" lift over the original springs on my 2012 LE FWD. For anyone else that sees this, here's a link to my thread on the install https://www.siennachat.com/posts/479055/
81 - 84 of 84 Posts
