Hybrid Battery indicator
1 reading
7.1K views 15 replies 12 participants last post by  Sienna.Guy
Does the battery indicator every get full? l aways have 2 bars not filled. I had a Prius a few years ago and it would get fully charged.
Thanks,
Mack
#5 ·
The battery indicator pretty much stays in the 3-5 bar region. It will get full if you have a lot of downhill where the car just regenerates power. Many areas just do not have that kind of hill. The car also tries to not go below 3 bars. However, there are reports of people seeing lower than 3 bars when climbing a long steep mountain pass.
#6 ·
The only time I see my battery "fully charged" is after going down a steep hill for a couple of miles. Normally, the computer is trying to keep the SoC in the 30-70% range. I also had a Prius in 2015-2020 and somehow I don't remember if the battery indicator behaved in a similar way.
Regarding the fuel efficiency: it's late November now, which means there are two factors that affect our mpg's: cold(er) weather and winter-blend gasoline, which is typically less efficient than summer-blend gasoline. Between these two factors we expect to see the fuel efficiency drop by 10-15% against the baseline.
The factors that affect our fuel efficiency all year round are the driving style, the ways we use our vehicles, and the road conditions.
#8 ·
Also, the hybrid batter meter / gauge does not represent 0 - 100%.
Haven't had a chance to investigate but for my old gen 1 Prius, the visible gauge was for about 60-80%. Need to connect my tech stream to see the real percentages.
I'm guessing the Sienna gauge represents about the same 60-80% range. 8 bars can be anywhere from 80-100%. 1 bar is anywhere from 40-60% and won't go down to zero since ICE will kick in long before 0%.
#12 ·
Very normal on the Sienna. But on our Corolla Hybrid it can get all 8 bars especially the first few minutes of driving. But mostly 7 bars. On the freeway the sienna will stay at 3 bars on long drives. 5 bars on the Corolla (Li-ion equip).
