Oil Pan Replacement Lessons Learned (Gen 3)
7.5K views 3 replies 3 participants last post by  firemarshalbi11
I have a 2011 Toyota Sienna V6 3.5 L. Last night someone threw something out their truck and it nailed my oil pan and put a leak in it. I was just wondering if anyone has any lessons learned from dropping the oil pan on this vehicle. Does the engine need to be lifted at all or is it pretty straight forward.
Thanks,
Chris
Discussion starter · #3 ·
Well for anyone interested I got this done a couple nights ago. Wasn't a big issue except their are two studs to help align the pan along with all the bolts. One stud was located right above the car frame and proved difficult to get the pan out with it in the way. I ended up prying the pan out around the stud. Was going to move the stud to a different hole that was easier to get to but it bottomed out on the frame so I gave the stud a trim to get the new pan to fit in nicely. Other then that it was a fairly easy task but two bolts are quite difficult to get to. I'm willing to bet someone put this stud in the wrong location during assembly so perhaps others wouldn't have this problem.
Chris
