I am starting a new thread as I wanted to be sure of the catalytic converter and oxygen sensor locations on the vehicle.The code I am getting is PO430 for catalytic converter inefficiency Bank2 . I want to confirm with someone with a diagram that the associated CC and O2 sensor are located next to the radiator and not the firewall. Also if that sensor were bad wouldn't there be a code specifically for that sensor? I know there is a code for the heater on the sensor as I had that previously for the other sensor. Though I have been told that the cat itself could be bad I want to try and eliminate a few things before I spend for an expensive cc...thanks
