Sorry it took so long, I had to dig through old folders to find these photos.
I remember that after adding the new wheels and tires that it drove so much better. The handling was significantly improved, I'm guessing due to the stiffer side wall.
It's tough to compare how it drives compared to before the lift because it's had a very annoying problem since doing the lift - there is a clunky coming from the steering when turning at low speeds. I dismantled the suspension numerous times trying to figure out what I messed up. It turns out it has nothing to do with my modifications, although they may have exacerbated the problem that was already there - the intermediate steering shaft issue that is a not-uncommon problem to our Siennas. $200 and 2 hours later and now there's no clunking.
The other problem it had was vibration at high speeds. I've gotten numerous wheel alignments and the issue keeps coming back. It starts out good but then gets worse again. Sometimes it's rather scary. I believe what the problem was is that Discount Tire, who I ordered the wheel and tire package from, did not put the hub-centric rings on the wheels. The Sienna hub is like 66mm, and the wheel hub is like 72mm, so it gave lots of room for error. Yes, the lugs could keep it centered, but they're not designed for that. So now that I added the hub-centric rings, it is driving much better, and staying that way. But there is still some vibration at high speeds, but I'm hoping it's just that the tires have worn unevenly over the time that the wheels were not properly centered.
[url=https://flic.kr/p/2h5jY7p]
[url=https://flic.kr/p/2h5jckz]
[url=https://flic.kr/p/2h5jY4i]
[url=https://flic.kr/p/2h5hqd9]
[/QUOTE
Odd,
Beautiful and an inspiration, did you finally resolve your vibration issues. As for your lift did you use the method designed by 4x4cal or the journeys end kit. I thought that I read that you had to shortened the link by cutting and welding the parts together. I don’t have your welding skills , would the Godspeed adjustable link accomplish the same thing.
I’d like to approach the lift in a more incrimental fashion. Could you recommend a stepped approach that I could use. For me, I’d prefer a lift less aggressive than Journeys, although I’ve been very impressed with mikes support and willingness to answer all of my questions. Additionally he
provides the installation of his kit at a reasonable cost, which is another option
Thx,
Jim
