13.
Remove floor panels/kick panel
- As shown in picture Fig 9 in picture below.
- Passenger side - you need to remove glove box by taking out 2 screws and 2 10mm bolts as seen in picture Fig 11 in picture below.
14.
Unplug this 2 wire harness connector
- As shown in Fig 10 in picture below for passenger side.
- And shown in Fig 8 in picture below for driver side that supplies power to mirror and door.
15.
Remove top rubber grommet
- By using a long nose pliers or nylon prying tool while pushing the wiring harness you just unplugged from the inside to the outside.
- Once the rubber grommet is taken out, position it vertically (reposition rubber gourmet so it is not twisted) in between the door frame and vehicle body as seen in Fig 2 in picture below.
– This will make the wire go through easily and easier.
- Guide a hanger wire through and turn signal wiring through it and insert it through the opening where the rubber gourmet came from.
- Reinstall rubber grommet starting from the top one – start to insert the front to rear of the top rubber grommet.
- Do the bottom next – easy one.
- Do the same thing on driver’s side and reinstall speaker and door panel.
16.
Wiring connections
- Wire from LED turn signal lamp
: Black is ground
: Blue is parking light – white LED
: Red is turn signal – yellow LED
- NOTE: You can opt to use parking light or not by not using/connecting blue wire.
- I opted to use it with a switch so I can turn if off and on if I need to.
- I have this LED switch as seen in Fig 14 in picture below from MIT in my other vehicles and liked it so much.
- Fits in the blank slots perfectly like a glove and lights up(DRL) when parking light is on/LED parking light off at night in matching green color and on indicator (see two pictures below).
17.
Tapping wires
- See picture for wire color code for parking light below.
- See picture for turn signal wires below.
