Add me to the list too. We are the original owners of a 2004 Sienna XLE of which we have had serviced on a regular basis and have replaced/repaired items as needed.
The traction control has engaged four times, once each in September and October 2015, and twice in the last ten days (January 2016). Three out of four times the van was traveling on dry pavement, all four times traveling between 35-45 mph. The first time it happened it scared the heck out of me. The van seized up (braked on its own) and an internal audible alarm sounded (after owning the van almost 12 years I was quite surprised to learn there was an internal alarm). I immediately pulled over, got out and check the tires, looked under the van, and while I didn’t open the hood there wasn’t any steam, hissing sounds or sounds of fluid draining. I got back in and proceeded with caution to my destination. I then took the van to our independent mechanic, with whom I took a drive with as he ran diagnostics on the - unfortunately nothing showed up. After the second time, our mechanic did some research and learned the problem was probably due to a faulty sensor. He has recommended (which my husband agrees with) disconnecting traction control, since after owning the van for twelve years we’ve never been in a situation where we need traction control to engage. I have been hesitant to have it disconnected but after the last two incidents I worry that I could get into an accident if this was to happen again, especially if someone is following to closely or going through an intersection with on coming cars heading towards me. VERY SCARY. I have reported this to NHTSA. I also mentioned to my local Toyota dealer and at least one of the employees was familiar with the problem. We didn't get into a discussion about the problem as he was not a service tech and I was at the dealership regarding the dashboard recall. I plan on calling the local dealership tomorrow to further discuss this issue. I sure hope Toyota does the right thing by us vehicle owners.
