Has anyone come across a 2022 sienna that has to be jump started almost every morning - especially in the cold? Dealer couldn’t recreate the problem when we brought it in. Is there something that we are doing that is draining the battery? It’s not the lights we are militant about making sure the dome/map lights are off.
thanks,
Andrew
I'm in Canada. 2022 XSE AWD. Battery has drained 11 times in the 7 weeks I have owned the van.
It could be worse, but i installed the COMFORT+ package that comes with a battery charger. Takes about 15 minutes to charge the battery enough to start the van. It's a good idea to get that type of package in Canada, but honestly I never thought i would need it unless it hit -20C. I need it everyday to get the battery enuf juice to get out of the driveway
I was at the dealer today. They tested the 12V battery and say it's perfectly fine. Their opinion is the DCM is failing to communicate properly to Toyota's Satellite and it's causing just enough of a drain at 300 mA to drain the battery.
Dealer mechanic pulled the fuse to disable the DCM, and we are going to go 2 weeks and see what happens.
They don't believe it's a wire harness issue,and there are NO fault codes getting recorded by the van
The DCM draining the battery was a problem in 2020 and 2021 RAV4 and Camry. The big problem here is there is NO SOFTWARE updates for 2022. And I'm in Canada and we might get our own software update which could take longer.
I don't like the thought of the DCM being disable. Toyotas are highly stolen cars in Canada esp Highlanders, Tacomas and Siennas. the DCM allows Toyota to track stolen vehicles. I bought an Apple airtag for it.
I'll try to update, but for now dealer told me to keep driving and parking as normal and begin to track battery drains. Cross our fingers it's this DCM celluar issue!
